Moving a group of objects.. body, sketches
I have a design the consists of a main body, and a few extruded sketches. I need to move them all over 5" and while it seems like that should be easy, I have not had much experience.
I simply can't do it.  How is this done?  The move command does not want to move them all at once.
ryan.bales
Autodesk Support
Autodesk Support
It would be best to move the sketch geometry from within the sketch. The profile should remain intact and the subsequent extrusions should update their new location. Moving the bodies will result in an error if they are dependent on the sketch profiles.
Honestly i just roll back the timeline to each sketch in turn - make the moves from within the sketch - then step the timeline forward.
Ryan Bales
Fusion 360 Product Support
