Move tool slow
Move tool slow
Move tool slow
Whenever I want to move a body which is slightly more complex, I have to wait everytime before I can move it.
Timeline is off, it is just a body. Is this already too much geometry and causing the lag? (my workstation is not the problem)
HughesTooling
What have you got the "Move Object" set to on the move dialog. Just did a test on a design with 41 bodies and it moves around easily but if I select as Faces I have about 950 faces and moves are very slow.
Mark
Mark Hughes
Owner, Hughes Tooling
Of course I choose "bodies" in the Move tool. I think it's something with the history. The more history there is, the slower it gets. In larger assemblies it gets even worse. For me it's the first time using Fusion for a project. I am coming from Alias where I just take care of layers and some construction history. So in this project my organization of the model is really crappy. Not knowing the right work flow and management inside a project I have been modeling very spontanously. I learned about base features too late. Regarding the organization of a model/assembly the learning curve is flat.
