Move/Copy fields are often missing on OSX.
WeLaunchFour
WeLaunchFour
F360BR-Move.pngSee attached screen capture from when I select and try to move a hole. It happens in sketch mode too, but only sometimes.
There are times when I can scroll the popup window to see XYZ options.
Clicking translate icon and It's worked, but IIRC this hasn't always been the case. Maybe this post will help others experiencing this phenomena.
sutherland-
Hi @WeLaunchFour
Could you please explain what is the issue? It is not clear form the image you provided.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
WeLaunchFour
The X, Y and Z move fields were missing. Maybe I wasn't in translate mode.
Hasn't happened again. I'll update this thread if it does.
sutherland-
Your move type is set to Rotate. Change it to Translate or Free move.
Best regards,
Level  sutherland-
Member
