Mouse zooming bug in new version V.2.0.8111 | April 13, 2020
crueby1
Message 1 of 25
crueby1
In the new version just installed, V.2.0.8111 | April 13, 2020, it no longer allows me to zoom the display in/out with the middle mouse wheel (Win 10 PC) when in the middle of an operation like the Move command, creating a primitive like box or cylinder, or while in sketch mode and drawing a line/circle/etc. This worked fine before the update, now it ignores the mouse wheel in all those situations. It still will zoom if the zoom button at the bottom of the display is clicked, but then I need to exit that mode and go back to the operation, very clumsy.
Replies (24)
Message 2 of 25
jhackney1972
Check your preferences and see if the Fusion 360 update possibly changed your Pan, Zoom, Orbit shortcuts setting.
John Hackney, Retired
Message 3 of 25
Phil.E
@crueby1
Thanks for reporting this. I am investigating this now. (UPDATE BELOW)
  • (Please do not reinstall Fusion at this point)
Phil Eichmiller
Software Engineer
Quality Assurance
Message 4 of 25
Phil.E
Please check this setting on your computer. Allow inactive window scrolling.
Phil Eichmiller
Software Engineer
Quality Assurance
Message 5 of 25
Phil.E
We now think this is a bug. The mouse setting should not be required for mouse wheel zoom to work for you. Please let us know what you find. The goal is to fix this soon, so the workaround is only temporary.
Phil Eichmiller
Software Engineer
Quality Assurance
Message 6 of 25
crueby1
Okay, tried those things. The inactive-window workaround DOES make it work, though I have never had that on in the past, and dont really want it to be since it would change behavior in other programs. But, it does fix that issue. I noticed that in this release, when doing an operation like creating a box, the way the windows go active/inactive is different than it used to be, or at least now I am noticing it!
Thanks for looking into this one, can run any other tests you would like me to.
Chris
Message 7 of 25
didjital-shurco
I don't have that option under mouse settings.
Message 8 of 25
crueby1
Took me a while to find it first time - on Windows 10 go to Start/Settings, then Devices, then down the left side click on Mouse, then it showed up. Dont know why MS puts so many varations of those controls in so many places....
Message 9 of 25
didjital-shurco
I'm on Win 8.1--- it doesn't have that option.
Message 10 of 25
HughesTooling
The wonderful forum software deleted all my text when I added the screencast! How much do the forum software developers pay Autodesk to test their software?
@Phil.E  Is that option available on Win8.1
Here's a screenshot of what I see, clicking the title bar get focus back to Fusion. Seem to remember this bug happened before a few years ago. Any idea when it'll get fixed? I held off updating until today, wish I'd held off longer now!😣
add12221-951c-494b-81fa-d1d3ade3fcd3,640,620
Mark Hughes
Owner, Hughes Tooling
Message 11 of 25
HughesTooling
Here's the screencast as the useless forum software will not let me have text and a screencast in the last post.
Mark Hughes
Message 12 of 25
Phil.E
@HughesTooling  This did happen a year ago and it is related to that event. We were able to work around it for Win 7/8 last year, and that workaround just expired, so to speak. Win 10 is not affected. The scroll inactive windows setting is on by default for Windows 10.
That leaves win 7/8. Right now, the best remedy is an app like this one to bridge the gap while we sort this out.
http://www.softwareok.com/?seite=Microsoft/AlwaysMouseWheel
Phil Eichmiller
Software Engineer
Quality Assurance
Message 13 of 25
HughesTooling
@Phil.E  Thanks, the utility you linked to works well.
Thanks Mark
Mark Hughes
Message 14 of 25
j.banks
Yes this worked for me! But it would be ideal to not have to change settings. lets just keep things working and stable!
Message 15 of 25
crueby1
Just to bring this one up again, it is still there in the new May release. The release notes mention a different mouse wheel bug that was fixed, still hoping this one (which is a fairly new bug) can get fixed soon as well.
Message 16 of 25
Ketherton21
right? why cant we use V bulletin like every other forum on the planet. fusion and its desire to reinvent the wheel.🙄
Message 17 of 25
crueby1
Still there in the latest release - this bug was created by some change in fusion recently, should not be that hard to find. Yes, the workaround change to the system settings works, but it messes up every other application, so we have to keep changing the setting back and forth when going to use Fusion.
Message 18 of 25
HughesTooling
@Phil.E  Just a heads up. Seems like the AlwaysMouseWheel program might be causing problems in the 2d drawing workspace. See screencast below. So the question is, is Fusion getting a fix so we don't need to use the AlwaysMouseWheel program?
Thanks Mark
Mark Hughes
Message 19 of 25
crueby1
Another few months, still not fixed. Any progress/work being done on this one??
Message 20 of 25
almiradjo
When will this problem be solved? I use Fusion 360 every day. You try to work without middle mouse button and you will see the problem we are facing.
