mouse offset problem
valar512
Observer Observer
Message 1 of 15
valar512
Observer
Observer
Similar problem was described here but the solution does not apply to my situation as it is not just on the model but it is also affecting other parts of fusion.
https://forums.autodesk.com/t5/fusion-360-support/fusion-doesn-t-know-where-my-mouse-pointer-is/m-p/...
Basically, the cursor is in one position, but the selection is offset by a bit, making it confusing and difficult to select tools. Also, This was not happening a few days ago.
I am using macOC Monterrey on an M1ship
Here is a recording of the problem:
https://youtu.be/u_PfKgVJTv0
Replies (14)
Message 2 of 15
lance.carocci
Hi @valar512,
Could you please give me some more details about your hardware environment?
  1. Does this issue persist through restart? If not, does it start or stop with any particular behavior?
  2. Have you recently changed display resolution or scaling, including when attaching/detaching an external dock or display?
  3. Are you using a mixed DPI environment - that is, one display with Retina scaling enabled, and one without?
  4. Are you using Fusion with macOS Spaces, such as in fullscreen, or windowed mode on a different virtual desktop?
  5. Please note any potentially relevant display or input hardware, such as a 3DConnexion Spacemouse, Magic Mouse, external display model/specs, or cursor/input capture or mirroring software.
Thank you!
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 3 of 15
valar512
Observer
Observer
  1. >>>Does this issue persist through restart? If not, does it start or stop with any particular behavior?<<<
    Yes, I closed everything, re-started the laptop and the issue persist. Also, itt only seems to affect the work area.
  2. >>>Have you recently changed display resolution or scaling, including when attaching/detaching an external dock or display?<<<
    No
  3. >>>Are you using a mixed DPI environment - that is, one display with Retina scaling enabled, and one without?<<<
    No
  4. >>>Are you using Fusion with macOS Spaces, such as in fullscreen, or windowed mode on a different virtual desktop?<<<
    No
  5. >>>Please note any potentially relevant display or input hardware, such as a 3DConnexion Spacemouse, MagicMouse, external display model/specs, or cursor/input capture or mirroring software.<<<
    None, using the laptop and building trackpad, no external anything.
    macOS Moneterey version 12.3.1
    Chip Apple M1 Max
    Memory 64 GB
Message 4 of 15
lucas.ballocchi
I have the same issue after the last 2 updates the pointer is offset making it hard to work. Also for the dropdown menu I have to hold the mouse button for the menu to display properly. The issue is with the trackpad and mouse. After reset the issue persisted even after a pram reset.
I have a MacBook Pro 2.6 ghz intelcore i7
Message 5 of 15
valar512
Observer
Observer
I know this will not be of any help but the issue on my end resolved after a week. I tried everything without luck and even got used to the new quirks. After a week, the issue resolved but sadly I do know how what did the trick.
Best of luck!
Valar512
Mac M1max
OSmonterey
Message 6 of 15
rprovideo
I have the same problem. I do change between my laptop's screen and a bog screen on a USB-C dock in the office. Is there a solution?
Message 7 of 15
karina.harper
Autodesk Support
Autodesk Support
@rprovideo
We are tracking this issue internally as FUS-109399, the current workaround is to reset/resize the window - I double click on the top bar of the window and that resolves it for the session.
Cheers,
Karina
Message 8 of 15
lucas.ballocchi
Thank you, I think the latest update took care of the problem at least on
my end.
Message 9 of 15
lucas.ballocchi
I figured it out, at least for Mac User, the problems is caused when starting fusion in fullscreen mode, to get rid of it just leave fullscreen mode , close fusion and then open it again and the problem disappears.
Message 10 of 15
karina.harper
Autodesk Support
Autodesk Support
@lucas.ballocchi are you still seeing this behavior? I am not seeing this when I launch in fullscreen mode. All looks correct to me. What build of Fusion are you on?
Cheers,
Karina
Message 11 of 15
lucas.ballocchi
Yes, it just started today again probably after the update. Fusion version:
2.0.14113 MacOS 12.5.1 x86_64 Macbook Pro 15,1.
Solved itself after restarting in windowed mode.
Message 12 of 15
karina.harper
Autodesk Support
Autodesk Support
@lucas.ballocchi
Hm.. I'm on nearly the exact same setup and I can't reproduce when launching in fullscreen.
Karina
Message 13 of 15
Piotrek_Szarek
Hi ,
Today I had same problem , I wanted to post it but I found this thread .
I didn't change any hardware or software , I was opening F360 randomly ( fullscreen / window )
Im using external monitor with another resolution and windows size .
to solve it I plugged off monitor , switch to window mode , fusion is good , plugged monitor . Now it works in fullscreen and in window correctly .
Unplugging monitor only , doesn't solve the problem.
MacBook Pro 2019 , newest macOS .
Message 14 of 15
JWolf2
Community Visitor
Community Visitor
That actually worked for me. Then I just manually resize the window, but do not let it go full screen. Thanks. I love Fusion, but this problem made it extremely hard to work with.
Message 15 of 15
JWolf2
Community Visitor
Community Visitor
I looked further down in the comments. I saw one from a couple of years ago. Try clicking on the top of the page and pull down slightly to get it to come out of full screen, or click the box to make it come out of full screen (restore down) and that fixed it for me. Something about being in full screen screws it up.
