Motion Link won't take into consideration Resting Position for joints...
petrara
petrara
I have a motion link between two revolute joints. Each joint has a resting position assigned, so it acts visually as it's spring loaded.
Attaching a motion link to those two joints "breaks" the resting position value and the now linked motions move without jumping back. Not sure if this is a bug (looks like a bug), or intended behavior.
This model was made for the sole purpose of learning, so any question like "why would you want to do this in the first place" will not be answered. So, please if you can help me to understand the limitations of Fusion in this particular situation, or where I did wrong and how this could actually be made to work as intended, it will be much appreciated.
Not sure if contacts sets is a good idea, as I was reading that is actually demanding in terms of computing and the better option is always motion link (unless really needed to use contacts sets).
Attached video will explain better.
Thank you.
masa.minohara
Hi @petrara ,
Thank you for posting in the forum! This is a known issue and the development team is looking into this right now. (FUS-18636)
I apologize for the inconvenience, and I'll post more information as soon as I have one.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
DAVID.LEWIS149NS4G
So... it's been a couple of years since you pledged to post more information, and I still have this problem. So... what's next?
CampStreeter
Observer
Observer
Any updates on this? Motion link completely stops rest from working
CampStreeter
Observer
Observer
Any updates on this? I tried search for help about motion links stoping rest from working but this is the only link that will show up that is talking about the problem.
