Motion link in gearbox not working as intended
Ralf.Burda
Ralf.Burda
I've just stumbled into a problem. I've done a small gearbox and now want to animate it properly. After some weeks of success and incremental andvances, I'm now stuck in a dysfunctional situation as follows.
a) I open a new construction and save it.
b) i link in two shafts (which basically are cylinders of defined length)
c) I add two spur gears, modul 1, 16 and 9 teeth.
d) I link one gear to the first shaft, the other so the second. Using both rotational joints with no restrictions
e) I select both joints (first the 16 teeth, then the 9 teeth) and add a motion link.
  => both wheels start to turn. unaligned as expected
f) I enter the gear ratio as -16/9*360deg for the second (9 teeth) wheel
  => the input wheel stops it's rotation while the dependent gear keeps spinning
I've attached my little test project. No clue what has happened. About 5 days ago my whole gearbox was working properly.
Any suggestions what I did wrong?
Cheers
Ralf
Ralf.Burda
Ok 😞 Simple answer.
I should have booted my machine. (lol)
Coming back home and starting from here... everything works as intended again.
@Anonymous team: Any flaw which I might have triggered unknowingly?
Cheers
Ralf
