[More] unstable when offline?
ltomuta
Advisor Advisor
ltomuta
Fusion team is currently "updating services" and so Fusion is offline and ... unusable. I can take the offline part, the file I opened is cached, the project is small and all should be fine. But CAM is totally messed up. Every click I make anywhere in the app turns the app unresponsive, the Browser goes black ...
It took a dozen of such click-froze cycles for Fusion to finally get to a stable state where I could actually investigate why the model component I used in my setup is larger than the visible object.
FacebookGroupMember
Turn the net off on the computer then restart it and leave the net off.
FacebookGroupMember
That may be a valid workaround but I'd rather have the team acknowledge the issue and work on removing the blocking loops
ltomuta
Looks like it would help if our profiles would also include the Facebook profile so that replies posted on Facebook could be mapped back to a forum user.
daniel_lyall
Yes it would be, sometimes killing the net will solve the issue as something is stuck and being offline let's it become unstuck then next time you start it with the net on it could well be fine.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
FacebookGroupMember
Ok this needs fixed.
FacebookGroupMember
It has been asked that people get asked the question to have there handle on display or not, I have all ready but we will see what happens.
