Monetization Validation Issue with Educational Version of Fusion
assiddiq_bourihane
assiddiq_bourihane
I am experiencing an issue with the educational version of Fusion. Every time I try to generate a dynamic or static simulation  , I receive the following error message:
Error: Platform Error.
Cause: Failed to validate monetization.
Action: Please try again later. If the problem persists, click Contact Support, then
1. Click Post-Purchase Support
2. Click Help Using My Software
3. Select Fusion
henderh
Hi @assiddiq_bourihane,
This error can occur if the time set on your machine too far out of sync with the internet time.
If so, could you try the following?
Windows:
  • Start > Settings > Time & Language > Date & time > Set time automatically > On
Mac:
  • System Preferences > Date & Time > Set time and date automatically > On
If you're still having issues, please attach the diagnostic log files when you see this error and development can investigate.
  • Help pull-down > Support and Diagnostics > Diagnostic Log Files
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
kmccandlessEMVGJ
Community Visitor
Community Visitor
receiving the same error, however how do I fix it without turning that on, because I live in AZ, and we don't do daylight savings
henderh
Hi @kmccandlessEMVGJ,
Could you email the log files when this occurs?
  • Help pull-down > Support and Diagnostics > Diagnostics log files
Development would like to investigate this behavior, and we apologize for the inconvenience this is causing.
Thank you,
Hugh Henderson
