Modeling Sketch Dimension
JAMWORKSLLC
JAMWORKSLLC
Associate a dimension from first created dimension.
For example, if I create two circles, dimension the first circle to .25" and hit enter, now when I dimension second circle and the dialog box pops up, I click on the first circle dimension so this dimension can be copied and associated with the first. This no longer works and the dimension needs to be typed for the second circle. Meaning I no longer get associativity between the two. This may have happened in the last update as this has worked in the very recent past.
PS: We are also seeing Fusion Team issues among members. Not able to create or join projects.
HughesTooling
I'm going to guess you do not have record history enabled? Without history you do not have parameters.
Mark Hughes
Owner, Hughes Tooling
JAMWORKSLLC
Yep, that was it. Not sure how it got turned off but it was. Thank you.
