Model wont show in simulation environment
Hi everyone i imported an IGS file then insert into assembly then which to simulation and the model won't show
please help it is an urgent
masa.minohara
Hi @Anonymous,
Thank you for posting! Could you check if the display of the body is turned on?
Are you seeing the issue as soon as you switch to the Simulation environment, or does the issue occur when Fusion shows the simulation result? Could you attach a screenshot of what you are seeing and share a public link to the design with me?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Hi
As soon as i change from model to simulation environment a pup up appear, if i click ok my model wont show the model bulb is turned on.
masa.minohara
Thank you for your response! Would you be able to share a public link to the design with me? I'd like to take a closer look at it.
Masanobu Minohara
