Model went missing
Model went missing
Bigtoy302
Model went missing
Bigtoy302
So yesterday I made a few changes in cam on a old model and it disappeared when I saved it. It is not showing up in the design space or the thumbnail in the data panel. I was able to open a previous version just fine then when I resaved it, it disappeared also. Any idea on what going on? I can't share the file publicly.
Marco.Takx
Hi @Bigtoy302,
When you open the file, is the model within the Design workspace visible.
If it is turned OFF you don’t get a thumbnail.
Fusion uses the design workspace to create a snapshot of the design that is visible.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Bigtoy302
Ok. So I partially figured it out but still no thumbnail. The model is just super zoomed in when you reopen the file. I can save it zoomed out but close and reopen it's zoomed way in.
Marco.Takx
Hi @Bigtoy302 ,
have you pressed F6 and then save that view.
Marco Takx
Bigtoy302
That seemed to do it for the most part but it still turns off some of the models even though they're visible when I save.
