Model is using cached geometry to solve
bobvXR2R6
bobvXR2R6
Still pretty new to using this software, but I am working on modeling a steel table frame and had made one change to a sketch done at the beginning of the model, but when I change that sketch, I get this warning (in the title) which effects 7 bodies. The issue seems to be happening where I took the bodies and copied them into a separate component to make the model browser more organized. I've tried adding the component at the beginning of the model to avoid this, but when I do that, it will not allow me to add the bodies to that component. If I delete the copy and leave the bodies as they were in the beginning, the change effects a bunch of my work down the timeline. Looking for an alternative solution to rectifying this . Below is a link of the file if I am being a little unclear.
https://a360.co/2PKLcWG
davebYYPCU
Model arrived with only one edge error in a fillet, until I did Compute All.
edit the fillet feature, and reselect the correct 9 edges, and the fillet works fine.
File browser stuff is beyond my level to help...
@jeff_strater can you find the guru?
bobvXR2R6
This link should show the issue in question:
Thank you for your help.
bobvXR2R6
I believe I found a resolution to the problem:
I removed the bodies that were effected by the warning and then I re-mirrored the parts over. Once I did that, I right clicked on the part of the timeline with the warning and converted it to a DM feature. Not exactly sure what that did, but I no longer have the warning and all my bodies are as they should be.
