Model bodies are invisible after update
michael55SE4
michael55SE4
I followed the instructions and cleared the cache and restarted, TWICE, and the bodies in the models are still invisible.   In some files the bodies are invisible, and in others, the bodies blink in and out of visibility as the POV moves.
The attached model should be an air filter as shown in these product pics:
https://www.3dupfitters.com/collections/air-filters-and-vents/products/fan-and-charcoal-air-filter
Instead, there are only sketches visible:
jhackney1972
The reason you are having difficulty seeing your model is that you have a bunch of Sectional Analysis activate.  The video will show you how to fix it.
John Hackney, Retired
michael55SE4
Thank you.  That is very weird, as I rarely use sectional analysis and certainly wouldn't leave it so nothing was visible.
What is the visual indication that sectional analysis mode is on?   I just experimented with that feature and there doesn't appear to be any indication of it's on or off.
jhackney1972
The indicator is in the Browser.  The Analysis folder only appears when a Section view exists.
michael55SE4
Thanks, I've never noticed an Analysis folder before.  I'll have to remember to delete them if I ever use section analysis again...
