Missing hole and thread command missing from drawing
richmanw
richmanw
Community Visitor
Community Visitor
Hi I tried to go to hole and thread notes under text in a drawing file, and that command is missing. I'm having to manually use the leader line feature, and write my hole notes. Please advise, also its not a single drawing its all drawing files, and on several different accounts and computers. I am a teacher at North Adams Community Schools.
jhackney1972
Not seeing it here.  Updated Fusion 360 this morning.  Photo would not insert, attached it instead.
John Hackney, Retired
richmanw
Community Visitor
Community Visitor
Sorry that doesn't work, please take a look at my screenshot. The command doesn't exist, if I need to update how do I do that?
jhackney1972
The current version is: 2.0.96.36  If an update is pending, normally a small "1" will appear in the location indicated by the red arrow.  If you are two many versions behind, the "1" will not appear, you have to uninstall Fusion 360 and reinstall.  If you have to do this make sure your use the Clean Uninstall method as outlined here.
Note: Again I had to attach the screen capture.
