Missing CAM Tool bar
I started up Fusion today and I added a quick sketch to a model I designed the other day. When I went to start the CAM on the part the toolbar wouldnt load. I tried restarting fusion and the computer, but it will not show up. All of the other toolbars in the different workspaces work fine. Fusion claims it is up to date as well. Any ideas?
paul.clauss
Hi @Anonymous
Thanks for posting! It looks like the CAM toolbar is not showing up in Fusion 360 for you.
The first thing I would try in this situation would be to reset Fusion 360 to its default layout. Please try doing so and let me know if it works!
If this does not resolve the issue, I would check to ensure your graphics drivers are up-to-date. I usually update mine about twice a year. Please check your graphics drivers and update them through the manufacturers website if they are not the most current version.
If this does not help, I would try to perform a clean uninstall using the utility at this link and reinstall Fusion 360.
Hopefully this helps! If you are still having issues, please gather your diagnostic log files and attach them to this forum thread - I am happy to continue troubleshooting!
Paul Clauss
Product Support Specialist
I went in and reset all of the defaults and the problem persisted. The graphics driver was also up to date. The only solution I found was a clean reinstall. I am thinking there was an error when the latest update was installed. I was asked to post the log files, but i am not sure I will still have them since I did an uninstall/reinstall.
Thanks for the help
I found the log files from when I was experiencing the missing tool bar. Here they are.
