Misplaced components
Hi!
I am trying to design a machine but after I have finished placing all the components with joints, everything loads out of place.
https://a360.co/2YpTtBQ
jeff_strater
@Anonymous - thank you for reporting this.  We think this is a known issue that affects component position when joints are used with external references after save and open.  Thanks for sharing the design, that always helps us look into these issues.
Jeff Strater
Engineering Director
After the recent update I saw that you can actually reintroduse a joint even if it conflicts with a previous one. It is more work but it somehow helps with the problem. Another solution that I found was the deletion of the grounding. It helped to an extend.
