Mirrored line doesn't cut through object when extruded.
m.haindl0720221
Observer Observer
m.haindl0720221
Observer
Observer
Hello everyone,
I am still pretty new and unexperienced with Fusion 360 but had a problem where I couldn't find or understand the solution to it in this forum. I mirrored a line and now want to extrude it on both sides so I can cut corners of an object. Somehow I can only extrude on the side where I drew the original line and not on the mirrored side. I don't get what the issue is - I assume for everyone in this forum it will be an easy task to find a solution for that. I added screenshots and the Fusion file.
Thank you!
Best,
Marlene
g-andresen
1. no screenshots attached
2. which components/bodies and sketches are you talking about?
günther
davebYYPCU
Because there is no profile (blue shading) on the mirrored side.  Project the body face into the sketch, and it will work.
Might help...
TheCADWhisperer
@m.haindl0720221
See Attached.
