Mirror Sketch on extruded face
i am have a hard time figuring out how to mirror a sketch on to an extruded surface so i can create the below leg. When i try to copy the extruded shape it does not allow me to
Marco.Takx
Hi @Anonymous,
Don't know what you are planned to do exactly but this is a way that maybe gives you an idea of how you can make it.
But there are many more based on what your goal is.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
MoshiurRashid
There are 2 types of mirror.
1. Sketch mirror (found in sketch tab)
2. Feature/body mirror (found in solid tab)
to use sketch mirror, you do it according to a line. but to do a feature or body mirror you need to select plane.
Are you trying to mirror a sketch according to a plane of a solid (using feature mirror)???
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
g-andresen
Please share your design and tell us which body should be mirrored.
File > export > save as  f3d locally > attach to next post
günther
