- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello
Axis through Cylinder 2 has lost his Referenz to the Cylinder after the Mirror of the Component
Christoph
Hello
Christoph
It is not losing Reference, it is just the length of the axis line that is not updating. I do not know how to make it update except to make the axis long enough to cover both configured components.
John Hackney, Retired
One solution would be to add an extra axis and then suppress the visibility of one or the other depending on the configuration showing.
Hello
@jhackney1972 wrote:It is not losing Reference, it is just the length of the axis line that is not updating. I do not know how to make it update except to make the axis long enough to cover both configured components.
You're right, that's true, thank you for your reply.
It is not losing the Reference, the problem is, that the axis is only updated when the hole is moved.
Christoph
