Mirror a Component - Axis Through Cylinder - Referenz is lost
Christoph_360
Christoph_360
Hello
Axis through Cylinder 2 has lost his Referenz to the Cylinder after the Mirror of the Component
Christoph
jhackney1972
It is not losing Reference, it is just the length of the axis line that is not updating.  I do not know how to make it update except to make the axis long enough to cover both configured components.
John Hackney, Retired
jhackney1972
One solution would be to add an extra axis and then suppress the visibility of one or the other depending on the configuration showing.
Christoph_360
Hello
You're right, that's true, thank you for your reply.
It is not losing the Reference, the problem is, that the axis is only updated when the hole is moved.
Christoph
