Message 1 of 15
I have this problem on fusion 360.
Someone know something about this ?
@TrippyLighting
I had the same question, but after staring at it for several minutes I realized that this is actually English,... upside down and backwards! I can't think of anything that should cause this.
Did your question get successfully answered? Then just click on the 'Accept solution' button. Thanks and Enjoy!
Chris Benner
Industry Community Manager – Design & Manufacturing
Ha ha, you are correct. Unreal!
It's in english but all characters are mirrored 😅.
I'm French, but i use the app in english.
Good Idea, i 'll start to change language.
this popup is inverted to
and click on the admin project is all messed up too. Click right on the bottom right make right click menu on other element (and reverted too)
Very strange behavior
After multiple tests, language, graphics drivers (DX9, DX11, OpenGL) nothing. The rest of the app works well, it's only on the part that use "web wiew", datas are from cloud on the mirrored part 🤔
Same after uninstall et fresh install :
Hi @cyril.regal, when did this behavior first start?
When did this behavior start?
-> Suddenly after an update to Fusion 360 if I remember correctly, I hadn't used Fusion 360 since.
The day of my post on this forum I made another update but that didn't resolve anything.
Do you have multiple screens?
-> Yes
Are any of them rotated or is the cable sensing the screen orientation?
-> No
Would you be able to provide a DXdiag report or details on your GPU/resolution/DPI scale?
(Note: this may display your username, which you may choose to remove)
-> I will generate one and post it
Are your GPU drivers up to date (new within the last year)?
-> I use fusion 360 in a virtualbox under Linux because the way of connecting has changed and with wine the connection on the browser does not connect the application and I cannot get past that.
Do you have any application scaling overrides applied via the Windows Application Properties panel for Fusion?
-> No
Thank you for your time and your response.
My DxDiag
Thanks!
devoptions.webdeveloperextras /on
in Fusion's Text Commands window and open the Chrome debugger, are there any errors?Hi @cyril.regal, initial investigation suggests that this is an occasional issue with VirtualBox's hardware acceleration and OpenGL 3D content. If you disable hardware acceleration for the VM, does the content show correctly?
I disabled 3d acceleration and it worked.
On the other hand, the vm has become quite slow and the fusion 360 startup time has become very long.
However, once opened it functions normally.
Thank you so much
I reactivated the 3d acceleration to test and again everything was reversed. This confirms that this is indeed linked to the bug in Fusion 360.
Thanks again.
