Middle Button not working
Dinutzu08
Observer Observer
Message 1 of 12
Dinutzu08
Observer
Observer
Hy!
Can anyone help me?
I cannot pan or orbit using the middle button
Middle button work great in Chrome.
I can zoom in Fusion 360
Fusion reinstaled ... nothink
Computer rebooted ... nothink
But works fine middle button in Fusion 360 in anover laptop
Replies (11)
Message 2 of 12
masa.minohara
Hi @Dinutzu08,
Welcome to the Fusion 360 community! This forum discussion may be related to your issue.
I believe you need to change some settings for your mouse. What mouse are you using?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 12
Dinutzu08
Observer
Observer
Thank you !!!
I uninstaled that logitech program and It’s solved the problem
Message 4 of 12
hey,
I assume by "that Logitech program" you are referring to Logitech Options, if so then no need to uninstall, just open the Logitech Options app, select your mouse and then click on the location where it shows the middle button on the image, and change it from "Gesture button" to "Middle button".
Message 5 of 12
Autodesk you have to consider some alternative option for users that may use some mouses that doesn't have middle mouse button.
E,g this Logitec (https://www.logitech.com/en-us/product/mx-anywhere-2s-flow) is a pretty good mouse but the middle mouse switches the rotation mechanism of the wheel and you can't adjust this in the driver options.
Message 6 of 12
hey,
well i have this exact mouse and you can set the button just above the scroll wheel as middle mouse button, just read my previous comment.
Message 7 of 12
The solution for me was to blow on the middle button (scroll wheel). Sounds like a prank, but it's not! Now I can pan using the middle button on my Logitech M210 mouse!
Message 8 of 12
It works, it sounds like prank but works
thanks for this suggestion
Message 9 of 12
philipML9W9
I have a Logitech M185, and my middle button began working intermittently which was frustrating. I blew in and around the middle button, and it seems to be working fine now.
Message 10 of 12
Holy crap, it worked. I almost felt silly trying it, but it worked right away.
Message 11 of 12
marco.guassone
Community Visitor
Community Visitor
Me too! I have a Utech smart venus gaming mouse and scroll was fine but middle button won't work. Blow and a bunch of "rage clicks" worked for me!
Message 12 of 12
newby.sa
Community Visitor
Community Visitor
Ok I have same problem with genius and logitech mouse.
Solution was to go to preferences in Fusion 360 and change the "Pan,Zoom,Orbit shortcuts option to Solidworks
This solved the problem for me.
