Microfreezes with latest updates
Hi all,
I am having some performance issues with Fusion since around March/April this year.
Mainly this means that very often there is a freeze/stuttering typically for a couple seconds (sometimes almost after each action I make)
Maybe calculating times of some other actions are actually reduced with latest updates, but it is not much of a help, when on the other hand I have to wait several seconds after every small action. And loading times of big assembly drawings etc. are still long anyway.
Right now it is quite bad, almost unusable to be honest.
The short freeze problem seem to affect drawing space mainly. Also new detail views and other views to some extent take really long time to create.
Honestly I am not sure if the assembly I am working with is more complex in regard to these drawing calculations, compared to the ones I created earlier (how could I check this?). I would guess it must be around the same (similar type of equipment and complexity of design).
Also I am using Win 10 (latest version). I think it should be OK.
I just wanted to check if any of you have the same problem (could not really find these symptoms exactly in earlier posts), if it is a known general issue to be fixed, or if it is a problem on my part (but maybe there is way to fix it?).
Thank you for any help,
Roland
