MESSAGE_SERVER_ERROR
asciencepotato
asciencepotato
I get this error every time i try to use the search function in fusion, i have hundreds of clients and it makes it almost impossible to find anything as i have to manually sort through all my projects instead of using the search bar. this has been an issue for about 2 weeks now
johnsonshiue
Hi! A quick Google search led me to the following article. Could you take a look?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Una...
Many thanks!
Software Test Engineer
asciencepotato
i followed the instructions and found the folder with the listed files in it, but the specific one it mentions is not there. in step 5 it mentions if the file is not there it may be an issue with the firewall, but when i go to the page that lets me choose which software to allow through the firewall fusion 360 is not listed, neither is any autodesk listing.
