Meshmixer Failure
Meshmixer Failure
Meshmixer Failure
Fusion 360 will not export to meshmixerwithout crashing every time.
error report CER_185349948
refers. This is the 3 report sent and no response from Autodesk.
TrippyLighting
YPu have share almost no information of any value. Can you share your model and create a screencast of the workflow ?
Many thanks for your reply. The part that I was trying to 3D print ( https://a360.co/2BSNGeY) as a proving of a string of parts was the simplest of all of the parts and I have as best I can sent the part into the public domain. I hope that this what you require. If not I can try again to assist you. I was using MAKE, generating an array of 1600 and then exporting to MESHMIXER. Meshmixer opened and then gave the failure notice. Regards Brian
