mesh scale not entirely working
DBVieira
DBVieira
After scaling a mesh on CAM the block assumes the original part size.
How to reproduce
1.Open an STL
2.Scale it <1
3.On CAM environment when doing the setup  the relative block size assumes the ORIGINAL part size
kate.raskauskas
Hey @DBVieira,
Thanks for bringing this to our attention! I've logged this with our developers (ticket CAM-8976).
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
innovatenate
Autodesk Support
Autodesk Support
Are you saying that after scaling, the setup doesn't update like in the below screencast?
I've reported this to development via report CAM-8977 for further investigation. For now you may be able to create a new setup, select the body and then copy your toolpaths over to the new setup.
I hope this helps.
Nathan Chandler
Principal Specialist
innovatenate
Autodesk Support
Autodesk Support
Doh! @kate.raskauskas beat me to it.
Nathan Chandler
DBVieira
more or less...is actually worse
The rotation and scale is compromised on fusion and not only on CAM areas.
The workaround is to export the transformed STL and import again
cj.abraham
@DBVieira A body needs to be selected in order for the stock to be properly applied.
DBVieira
Have you tried ?Because on mine still doest work.....
