Menu Artefacts
Menu Artefacts
mjBLGPA
Menu Artefacts
mjBLGPA
Hi
I am running Fusion 360 v2.0.12376 on a MacBook Pro with Monterey v12.2
I often get these kind of artefacts from the Fusion menu system. It pops up even if the app is minimised or hidden. In this case it's just over the desktop, but if you have any other app open the menu will be shown on top of the other apps. The menu is active so clicking on if will do the Fusion action, even if the app is in the background.
Only way that I found to temporary get rid of them is to open the app and then minimise or hide it again.
Does anyone else have this issue and know what can be done?
CGBenner
@mjBLGPA
Please share some images of what you are seeing, so that the experts in here can have a look.  Thank you.
Chris Benner
mjBLGPA
Hi
Here two examples where Fusion is not the active App but the menu is shown and being active.
In one case its below the active app and in the other case above it.
Happens several times a day for me. Got away for a while if I make Fusion the active app and then minimise it again.
Hope this helps
TrippyLighting
Yep, happens all the time, particularly when you work with a dual monitor setup.
mjBLGPA
Yes seems to be happening more with a dual screen setup.
Can also happen that part of the interface is on one screen (main window) but part of dropdown menus pop up on the other screen...
