measurement discrepancy between F360 and Meshmixer
rondennis
Observer Observer
Message 1 of 10
rondennis
Observer
Observer
A "z" measurement of 60 mm in F360 imports to Meshmixer (Vectric Cut3D also) as 54 mm. I need that 6 mm, any suggestions? Should I scale it up in F360?
Replies (9)
Message 2 of 10
karina.harper
Autodesk Support
Autodesk Support
Hi @rondennis
What file type are you using? If you're using STL body export, what settings are you using when exporting?
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion
What's New in Fusion | Contact Support | EDU Support | Support Board Best Practices
Message 3 of 10
rondennis
Observer
Observer
Using stl export from F360, what and where are the export settings (duh :-)?
Message 4 of 10
hfcandrew
Make sure your xyz axis are swapped (rotated).
Try a test with an asymmetrical object.
Please attach your file.
Message 5 of 10
karina.harper
Autodesk Support
Autodesk Support
+1 to what @hfcandrew said!
@rondennis Try exporting by right clicking the top level component -> save as mesh. That gives you more export options like detail level.
Karina
Karina Harper
Message 6 of 10
rondennis
Observer
Observer
Any thought as to which of the four "save as mesh" options I should choose?
Message 7 of 10
karina.harper
Autodesk Support
Autodesk Support
Which format? Depends on your usage, 3MF is a newer one that I hear is pretty great.
Karina
Karina Harper
Message 8 of 10
rondennis
Observer
Observer
I doubt that detail level has anything to do with a basic measurement but thanks anyway.
Message 9 of 10
joestolars
Oh Boy.
Not knowing how to Export $10
Replying to somebody with  help tip,  with a snide remark $ Priceless
Message 10 of 10
rondennis
Observer
Observer
I apologize.
