measure tool will only grab planes, not faces, edges or anything else.
The measure tool has stopped working in one of my models. It wont grab anything except planes.
When I change to another model it works normally.
I have tried to go back in the history and also opened older saves without any luck.
Anybody here with the same experience ?
Ulrik
g-andresen
did you check this setting?
günther
dsouzasujay
Hi @Anonymous ,
Can you attach the design that you have issue measuring in Fusion 360? You can export by File>Export *.f3d/*.f3d file to your local drive and then Attach it here to a Reply.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Hi.
Yes everything is on.
Ulrik
Hi.
Model is attached.
Ulrik
dsouzasujay
Hi @Anonymous ,
Expand Browser, Right click on Body select 'Selectable/UnSelectable'
And then it should be Measurable.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
A million thanks 🙂
