measure tool will only grab planes, not faces, edges or anything else.
The measure tool has stopped working in one of my models. It wont grab anything except planes.
When I change to another model it works normally.
I have tried to go back in the history and also opened older saves without any luck.
Anybody here with the same experience ?
Ulrik
g-andresen
did you check this setting?
günther
dsouzasujay
Hi @Anonymous ,
Can you attach the design that you have issue measuring in Fusion 360? You can export by File>Export *.f3d/*.f3d file to your local drive and then Attach it here to a Reply.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Hi.
Yes everything is on.
Ulrik
Hi.
Model is attached.
Ulrik
dsouzasujay
Hi @Anonymous ,
Expand Browser, Right click on Body select 'Selectable/UnSelectable'
And then it should be Measurable.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
A million thanks 🙂
