measure between 2 points not working, seemingly random measurements
Message 1 of 8
trying to measure from a hole centre to another hole centre line to get a measurement needed to design the next part but its behaving randomly and i have no idea why. thanks
Replies (7)
Message 2 of 8
wmhazzard
Specifically how is it randomly measuring? Are you using snap points in the measure command?
Message 3 of 8
dont think i had snap points on, but dont know why it did this? linked.
Message 4 of 8
Phil.E
@Anonymous  I didn't find anything attached. Are you still seeing this issue? An image or video might help. Glad to take a look.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 8
sometimes in models with lots of parts using the measure function will cause random measurements that have nothing to do with 1 or 2 points
https://autode.sk/3j1RbU7
Message 6 of 8
Message 7 of 8
Phil.E
It's not clear to me what is going on, but thanks for sharing the model and video.
While we're figuring this out, you can achieve the measurement by adding a construction axis to the cylinder. This should not be necessary, but it happens to help in this case.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 8 of 8
Thanks, its supposed to be a fold flat ramp, the geometry should make it rise and fall in a linear controlled way until the uprights are at 180 degrees. Havent put any locking detail in yet. Keep not being able to move it up or down at all despite adding motion links and im reasonably sure of the maths.
