Measure Arbitrary Distance in Cross Section... how?
glencandle
glencandle
I have a cross section analysis that cuts right through the middle of my part, and I would like to measure the thickness of a particular area within the cross-section (see attached).
There are no selection points available that I can grab that will will give me this measurement.  Is there a way to do it?
davebYYPCU
Not from a section.
There are other ways to work it out, dependent on how it was made.
Might help...
jeff_strater
create a sketch, use Project -> Intersect, choose type of Body, this will produce sketch geometry of that section, and you can measure (or even dimension) that.
Jeff Strater
Engineering Director
glencandle
Wow, exactly what I was hoping to find, thanks!
