Mazak Quick Turn Not Recognizing Fusion Tool ID
tyleradams8
tyleradams8
Mazak 250-MY does not seem to be recognizing the tool ID (Letter)
I have entered the Tool ID into the product ID in the Fusion tool library and changed the parameters in the machine (F93 and F94).. The code posts as G53.5 and I am using the updated QT250-MY Post.. It always seems to select the tool at the top of the tool library.
(Example) I want to select tool  8, with Tool ID-(G) but it just selects the first tool/offset at the top of the mazatrol library options for tool 8..
NOTE:the post does show the (G) designation at the end of the tool callout (example) T0808.G
But still doesn't seem to pull the offsets...
Running out of ideas..
Tyler
will_1
Hi @tyleradams8 ,
I may be misunderstanding the issue, but it sounds like a problem on the controller and not in the software/post processor. Have you tried talking with someone from Mazak?
Will
tyleradams8
@will_1 Yes that is a possibility, we run everything through the mazatrol with no outside CAM currently so I really am starting from scratch with the Mazak, I've been going through the manuals with no luck so far, Mazak support is pretty lacking, so I was hoping I was just simply doing something wrong in the post process..
Tyler
will_1
Hi @tyleradams8 ,
In my experience I have never seen the tool id output as a letter in NC code. It has always been a number. Is there a number that corresponds to the letter?
Will
tyleradams8
@ will_1
I have attached a picture of the tool controller as you can see for tool number 8, It allows a Tool Nominal Size and a Tool ID Code.
Currently the machine is selecting Tool (#8) (CTR-DR/ NOM-.25 / Tool ID-S ) and respective Offsets. * I believe because it is the tool at the top of the list..
I want to select Tool #8-(End Mill OUT/NOM-.5/Tool ID-F)
I tried to insert (.5)(instead of F) in the Fusion tool ID code but the controller did not like that and errored out..
Note* obviously I could just move my preferred tool and offsets to the top of the #8 list but thats not feasible long term..
tyleradams8
Figured it out.. So I guess they expect you to use numerics 1-26 to represent the letters that Mazak uses for the Tool ID Code in the controller..
Glad I figured that out but it creates another problem.. for example I use the letter B for my turning tools to designate an 55 Degree Turning Insert, there is an offset for the Face turning (EDGE) and a separate for the Radial Turning (OUT)
So Tool list reads as follows
2 General Out 2. B
2 General Edge 2. B
(C is used for 35 degree tools)
(A for 80 degree etc..)
The machine separates the two tools based on the Out/Edge designation... Fusion isn't doing this and just calls on  the first B it comes to...
What a mess..
