Manufacture issues (toolpath not following Stockbox)
Goysimon
Goysimon
Hi there!
Since the last update, i'm a bit stuck in my manufacturing process. I made a fast search about it and didn't find anything.
I'm using a manufacturing template for milling. Since this morning, the scallop actually don't follow the stock box neither the mesh integrated in the setup. The setup generate a part of the process, offset from the mesh and can't be use with my cnc since it dont generate a proper toolpath.
I join the file that i'm using if it can help. I didn't change anything and it work fine yesterday.
Hope you can help me, and if you know a way i can bypass the issue, i could be a great help!
P.S Sorry for the english, it's not my first language!
Best Regards.
Goysimon
For a quick view of the issues, this is two pictures, from the same program that i'm using. One of them show a proper generate toolpth and the other the ''broken'' one that generate outside the mesh.
Hope it could help!
Goysimon
After few hours, I manage to find the issue.
The last update didnt record the move/copy on added mesh in a design.
Once added, the mesh cannot be move or it will not be record by fusion 360. the manufacture process then is generate on the default location of the mesh and not the exact location.
Any support can fix this?
seth.madore
We're digging into the issue, bug reports have been filed. At this point, the only workaround I've seen is to convert the mesh into a BREP body, but that's not an ideal solution for everyone. Is that something you can try?
Seth Madore
Goysimon
Hi @seth.madore !
I just got called from another member of the tech support.
I didn't had the time to come close the thread by it's exactly what he showed me.
I'll will try it tomorrow and see if it can be a sustainable solution for the moment!
Thanks a lot!!
