Manufacture bug when selecting new components on new operation
When I make the first setup I select the component that I will machine, and everything runs great.
Then I make a new setup to work with another component, but I cant use the new body because the app dont use the new selection, try to use the body used on the first setup.
And tried to make a toolpath with the non-first setup to see if is just a view bug:
Tried with another files to discard a file problem, but still the same on all of them. the body that is keeping selected is always the body used on the first setup and no matter how much setups you create, still using the body used on the first setup that you created.
No matter if you try to create a new setup and dont select any body, Fusion keep using the same body.
Tried to change the first setup body, and no problem, it changed and can work with it.
But the other operations still using the first that you used.
I'd like to help solve this problem ASAP so if need more information just let me know. Thanks to fusion team and other members here!
