Making a tool, made the handle and the tool and can't press them together.
chuckA8JD8
chuckA8JD8
Tool needs to extend 20mm past the end of the tool
Just can't press the tool into the handle
jhackney1972
Your model is attached.  Simply use a Rigid Joint with an Offset.  It is up to you to Combine them together.  By the way, you are showing a lot of color in your timeline indicating some model errors.
Edit: Just in case you want a hole in the handle to accommodate the tool instead of just pressing the tool into the handle, I attached a second model.
John Hackney, Retired
chuckA8JD8
Thank you John for spending the time to help me.
I've looked at the steps in the timeline and some of it makes sense.
Some of the tools/features are not of my understanding but I will work
to understand it better.
Again, thank you.
After sleeping on this (before seeing your resolution) I thought a
better way would have been to design the tool inside on the flat of the
handle and then do a press/pull. Not sure if that would work, just
thought about it.
Have a great day.
chuck
chuckA8JD8
thank you so much for your time and finishing my model! Lots to learn!
chuck
