Make tab missing from new "UI"
How do I access "MAKE" from the new "UI" so I can 3d print my designs? Went back to the old "UI" and it works fine but could not find it in the newer version. Just hoping it will still be included as we move forward. "Fusion 360" is awesome and I recommend as often as possible to others.
HughesTooling
Did you look on the Tools tab? It should be the first menu on the tools tab.
Matk
Mark Hughes
Owner, Hughes Tooling
It is there just as you said, guess I have a little learning curve. Thanks
and loving your product and support.
I looked, and I'm not finding it under tools... If it was there, isn't any longer... Not finding it there, or anywhere for that matter. I primarily looked in both Design and Manufacturing, not able to find it anywhere....
HughesTooling
It should be here if you're using the new UI.
image.pngIf not try layout reset, Ctrl+Alt+R.
Mark
Mark Hughes
