Make a body from a shallow emboss on a complex surface.
akschu
akschu
Hello All,
I'm trying to take an object and color a parallelogram shaped pattern on it using my 3d printer.  The printer slicer is pretty dumb, so the best way to do this is to make the section I want another color its own body then import the bodies together in space then in my slicer I simply say this body is this color and that body is that color.  This is trivial on flat surfaces.  Draw something, extrude down, tell it it's a new body, split, and now you have a perfectly fitting plug you tell the printer is another color.
The problem is that I can't get this to work on a complex surface.  As an example I have I have a block with a feature cut in it and I'd like this parallelogram shape that is projected onto the surface to be pushed in 1mm (4 layers) following the surface shape and become its own body.
I tried to do this with emboss, but that doesn't seem to make a body and the cut only grabs the rounded part not the flat face, so I tried with a projection onto the face but now I can only select the flat face, and not the rounded segment.
I'm not sure the incantation to make this work.  Anyone have any ideas?  I attached the drawing if that helps.
Thanks!
g-andresen
1. create sketch plane at angle
2. project profile and create 1mm offset
3. sweep profile
4. combine cut
(view in My Videos)
günther
akschu
G,
Thank you for your helpful reply.  I didn't think of doing it like this.  Certainly more steps than I was hoping for, but totally makes sense!
schu
TheCADWhisperer
@akschu
Simple Combine.
See Attached.
lauri_barnhart
Hello, @akschu,
Just checking in—did the responses shared by @g-andresen and @TheCADWhisperer help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
