Machine definitions missing after update
Fusion updated last night and I dont see the tab where you pick the machine your using in setup still using old UI do I need to upgrade?
I'm getting the same thing, double checked that the preview options are still checked, everything is as it was.
My post uses some of the configuration variables to change output so now I'm hand editing everything.
bert_vanhooff
Same here.
Too bad really. I actually loved it already.
If you go in to your preferences uncheck hit apply, recheck and got apply it will work for that session but flake out again
karina.harper
Autodesk Support
Autodesk Support
@Anonymous @Anonymous @bert_vanhooff
Hi guys, this seems to be an error with the preview check box not being recognized (logged internally: CAM-12523). Here is a temporary workaround while we get this fixed. Note that any of the other options you see in here are beta - they are not necessarily supported and may have downstream effects so be aware of what you are changing.
Go to file -> view -> show text commands
Enter cam.featureflags in the dialog bar (make sure .txt is selected as the format) -> select machine-configuration
Hope this helps - but like I said this should be fixed very soon.
