Machine Builder needs Work Offset
joelsullivanP2CHD
Observer Observer
Message 1 of 1
joelsullivanP2CHD
Observer
Observer
The Machine Builder needs Work Offsets.  I should be able to position G54 - G59 in the Machine Builder.  When you select a WCS on a part it should move to that position on the machine.
Currently Fusion has all of the information it needs to correctly position a part in the vise.  G54 should align with G54, for example.  We have to manually approximate the position in the vise with little arrows and we can't make it snap, so it's inaccurate.  This is very time consuming and just plain worse.  The part should just snap to the correct work offset when you select a WCS.
Replies (0)
