Mach3 turn post processor problem
pllawrence0106
pllawrence0106
hi there
i went to post process a  drawing in fusion but a mach3mi.cps - generic mach3mill not in the list . mach3mill.cps is there but it come up with a error
Error: Failed to evaluate post configuration.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Sunday, October 8, 2017 3:39:05 AM
Loading locale from 'C:\Users\Peter\AppData\Local\Autodesk\webdeploy\production\04cb61898e148f81b3456870f9d2aa307abab650\Applications\CAM360\Data\Posts\common.en.lang'
Error(C:\Users\Peter\AppData\Local\Autodesk\webdeploy\production\04cb61898e148f81b3456870f9d2aa307abab650\Applications\CAM360\Data\Posts\mach3mill.cps:44): SyntaxError: missing } after property list
Failed while processing global script.
what can i do to fix the problem because it was all working fine last time i use fusion
regard
Peter
paul.clauss
Hi @pllawrence0106
Thanks for posting! It looks like you are having some problems post processing CAM operations to Fusion 360 using a Mach3 post processor.
I noticed in the title of your post you mentioned the Mach 3 turn post, are you attempting to post milling or turning operations? The Mach3Mill generic post (mach3mill.cps - Generic Mach3Mill) post will only post milling operations - if you need to post turning operations you will need to use the Mach3 Turning post linked here.
You can install the turning post to either your personal or cloud post libraries using the links below:
I wonder if you are not seeing the posts you expect to be because you are looking at a different library (generic, personal, or cloud posts). The library can be selected in the Post Process dialogue box under the "Post Configuration" field.
If you are posting milling operations, do they post correctly with the newest version of the Mach3 Milling post?
Hopefully this helps! Please let me know if you have any questions - I am happy to have a look at the Fusion program that is failing to post if you would like to share it with me.
Paul Clauss
Product Support Specialist
pllawrence0106
Thanks for your reply.
I have built a cnc router so i and using mach3 mill processor with fusion so what i nee to fix the problem using a mill.
I am new to all this and your help is very great
regard
peter
pllawrence0106
Got it all working now
Had to find the right file to put the download but found it and it works ok
Peter
