Mac trackpad zoom gesture engages very delayed or not at all
marc.liyanage
Message 1 of 55
marc.liyanage
Doing a two-finger pinch on my Mac's trackpad is supposed to zoom in or out in Fusion 360, but I noticed for a while now that this particular gesture is very unreliable. The zoom either happens with a long delay (seconds, not milliseconds) or sometimes it doesn't engage at all.
It is very noticeable and extremely distracting and annoying.
Below is a screen video that documents the delay between when the system starts sending the touch events vs. when Fusion 360 reacts. Make sure to display it in 1:1 full size to see the Terminal window properly.
Replies (54)
Message 41 of 55
marc.liyanage
I'm pretty sure you won't have to use a custom gesture library. The dtrace probes are triggering off events in *your* code (well, Qt in the event handler case, but definitely code under your control and not OS/framework code).
The results show clearly that the events are delivered by the OS and frameworks to your application layer code and that one part of your code (event handling) is getting the magnify events, but  another part of your code (drawing/rendering) is not always invoked in response to that.
I think there is simply a bug somewhere in the zoom handling that drops some of the incoming events on the floor, especially ones where the zoom speed is low. I think in the multi-second cases, it's not that the application takes multiple seconds to render. Instead, it drops several of the leading events and then finally a later event manages to tickle the rendering engine. So the rendering delay from that last event to the render happening might be low, but that's not what the user perceives. The user perceives the delay between the first gesture event to the first render after that, and that is exactly what the dtrace script demonstrates.
If you have some time, maybe try out the script, it's very easy to use. Given what I see in the video you posted recently, I'd be surprised if you get no warnings when you try it, I'm pretty sure I see the problem in your video.
Message 42 of 55
Phil.E
@marc.liyanage Thanks for your help!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 43 of 55
Hi there!!
Is this issue receiving some attention? Over  year after getting this help the problem persists. What gives?
Message 44 of 55
noelQUDAY
I would like to know as well. I really like Fusion, but this is an extremely inconvenient bug.
Message 45 of 55
marc.liyanage
I would not get my hopes up. From talking to people at Autodesk last year it sounds like they consider this not important enough to fix, ever. They think that this 3rd party extension is enough of a solution:
https://apps.autodesk.com/FUSION/en/Detail/HelpDoc?appId=2223881439415941299&appLang=en&os=Mac
If you disagree, I would make some noise. The reason they think this is not important enough is that not enough Mac users complained.
Message 46 of 55
noelQUDAY
It seems like issue has gotten worse for Macs recently. Now, rotating objects with the trackpad is often difficult. Is anyone else experiencing this?
Message 47 of 55
marc.liyanage
@Phil.E  It seems that the "Native Trackpad" extension is no longer maintained, according to another forum post:
https://forums.autodesk.com/t5/fusion-360-support/mac-orbit-using-trackpad-no-longer-working/m-p/100...
It was great and I used it for years. I know Autodesk's Knowledge Base article even referred to that for a while as a solution to work around the issues in Fusion 360's built-in gesture detection implementation.
With that option now gone, Fusion 360 is again unusable for me when using the built-in MacBook trackpad. Would it be possible to prioritize a real built-in fix in Fusion 360 now?
Message 48 of 55
Phil.E
Sorry to hear that Native Trackpad was deleted from your computer.
Version .13 is available on GIT, as the author explained
https://github.com/pravdomil/Native-Trackpad
Have you tried that version? It causes crash on start for some customers, but not all.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 49 of 55
gmooklee
It is old post, but.. I am still experiencing this issue.
Message 50 of 55
noelQUDAY
Yes it was never fixed, sadly.
I gave up on bringing it up. I really wish it would be addressed and fixed.
Message 51 of 55
marc.liyanage
Same here, I just can't understand why this seemingly serious issue was never fixed properly inside the app, to this day.
Message 52 of 55
tom3YYFC
Just adding my voice here that it seems a shame. I've got a 3D Mouse, but for linear orthographic views (sketch mode) it is pretty clunky and just simple pan and zoom are all one really needs - but it needs to work well. Here it just feels clunky and reflects poorly on the Autodesk brand for those of us coming from other CAD/CAM environments.
Message 53 of 55
dturbeville
Community Visitor
Community Visitor
Chiming in as well. This is an incredibly frustrating issue that causes me to waste time.
Message 54 of 55
Phil.E
Thanks for posting your comment.
Have you tried Native Trackpad? See this article
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 55 of 55
dturbeville
Community Visitor
Community Visitor
Brilliant! Thank you!
