Mac OS other users (guest user)
I have just installed Fusion 360 on my Mac and am unable to use it as any other user than the administrator. I need other users to be able to use the program without having administrative access to the machine - is there any way to do this?
ryan.bales
Autodesk Support
Autodesk Support
I think if they at least have accessibility enabled for mac they'll be okay. @baribak can you confirm?
Ryan Bales
Fusion 360 Product Support
I've added Fusion 360 in Accessibility, unsure if it works or not - as there is still no way to launch the application from the guest user...
baribak
Sorry to hear of the problem. Have you considered the Admin Install? This would allow multiple users on a single system.  This sounds like what you're looking for. The only caveat would be that the Admin account used to install Fusion should NOT run Fusion. All other accounts can.
On the Accessibility, you'd have to set that up for each account, install Fusion for each account as well.
Hope this helps.
Kevin Baribault
Fusion 360 Quality Assurance
Admin install is exactly what I was after - my google fu wasn't strong enough to find it though I guess.
Thanks!
