MAc install problem
MAc install problem
dlwalshRGGPF
MAc install problem
dlwalshRGGPF
Can install 360 on a mac!
Any suggestions.
It did work one time
RajkumarIlanchelian
@dlwalshRGGPF @Can you add more details? Are you shown any errors ? Does the error show a link where you can download logs?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
tkuechle
Yes, You will need to look at the minimum requirements to see if the operating system version on the mac is compatible with Fusion 360. You might need to upgrade the operating system on your Mac. Also, if you can't upgrade the operating system to one that works with Fusion 360, then there are one a few options after that.
