Lost Frames in Motion Study Render and Lagging Video Exports
Edgaras.Janušauskas
Edgaras.Janušauskas
After creating joints for components, I created motion study. In render environment, I have used cloud-rendering to render an image. After, option to render motion study appeared and I also used cloud-rendering option. However, exports where not what I expected:
  1. there are missing frames, even if motion study is done correctly
  2. motion study render exported as mp4 file on preview lags every second
I have attached an image (.png), that shows incomplete animations and a video (.mov) of original motion study animation. Also, I attached video (.mp4) in which you can see that the top cap is stopping two times when moving down.
Moreover, any updates on these issues:
https://forums.autodesk.com/t5/fusion-360-support/ui-elements-overlap-on-macos-catalina/td-p/1046198...
https://forums.autodesk.com/t5/fusion-360-support/red-lines-appear-on-imported-3d-pcb/td-p/10468094
mayank.malukani
Hi, Will it be ok for you to  share the model with us?
Mayank Malukani
Dev - Fusion 360
mohammed.aliTDPXK
Hello @Edgaras.Janušauskas ,
Just to follow up on this issue, our team is request for the model such that we can have a deeper look at the issue, would you be able to please send us the model?
Of its a confidential model, please send me a direct message and attach model.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Edgaras.Janušauskas
Good day!
Thank you @mohammed.aliTDPXK and @mayank.malukani for taking time to figure this out.
I have attached Methods.zip file with mp4, zip and f3d files of 4 projects: A1, A2 and B1, B1. In all 4 projects there are two components which are connected with a "CapSlider" joint and all projects have motion studies too.
Project A1 - motion study is set to 14 step and -20 mm. Zip file contains 15 frames.
Project A2 - same as A1 but in motion study cursor is moved to step 0 and 0 mm. Zip file contains 14 frames.
Project B1 - drive joint to -20 mm., create motion study and set to step 14, 0 mm. Zip file contains 15 frames.
Project B2 - same as B1 but motion study cursor is moved to step 0 and -20 mm. Zip file contains 14 frames.
In A1, A2, B1 and B2 video, you can see that frame 5 and 6 are the same and when cap is moving down, it stops for some time. These videos were exported from Fusion 360.
Also, I noticed that after recent updates, Fusion 360 doesn't start normally as it used to after an updates. It does update, then restarts but doesn't start. It is not responding and I have to close it manually. Moreover, when I created these 4 projects, I closed Fusion and it just crashed. Maybe, somebody already reported this?
