Lost bodies and corrupted CAM operations after save
Hi
Not for the first time, after saving and closing Fusion I've re-opened it to find it has lost LOTS of work..... After several successful saves, it has wiped out a number of changes, including in files which were saved days ago. There were no issues using the file, up to the moment I saved and closed this morning. When I re-opened, all recent work is lost, with even saves from a few days ago missing bodies.
The CAM operations I created are still there, but the associated bodies are gone (hence the red warning symbols). This has happened before and it is extremely frustrating, as I now need to go back to determine how much work has been lost. Based on the bodies which are missing, it's at least a week, maybe more). Now, I need to re-create bodies and all of the CAM toolpaths.
This has happened to me a few times on other files. As a hobbyist, I guess you can't complain when you get to use the product for free, but if I was considering moving to this as a side job, I'd struggle to justify spending anything on software which seems to break my files so easily. Given none of the bodies were linked (anything imported had the links broken, as I don't want to replace the original designs), so nothing else should be affecting the file. I should have realised when there were bodies which I couldn't delete, after turning capture design history on/off, that something was wrong. I can't understand how it has affected so many of the previous saves, which were absolutely fine at the time? Any assistance in troubleshooting would be appreciated, as I'm ready to give up.
