Lost all my projects
abdurrahmans338
abdurrahmans338
Fusion was stuck for an entire day trying to save a file I made. So I went in trying to cancel the uploads but nothing worked, I even left it overnight to get stalled upload but nothing happened. So I found that I should clear my cache and the moment I did that I lost pretty much all my projects and their assemblies even the ones I had with teams and I keep getting CB_URF - We're unable to synchronize your projects.
sutherland-
Hi @abdurrahmans338
Please try to follow this post, to see if it can help you synchronize the projects that you are missing.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
abdurrahmans338
Still nothing I keep getting something went wrong on A360 fusion personal drive and I am unable to find any of my projects except the pinned one that I was working on and even then its not showing in the fusion app. I did manage to recover the pinned project and switch storage but I am unable to sync my personal storage as of it
tasha.addington-ferris
Autodesk Support
Autodesk Support
Hi @abdurrahmans338 have you changed the email address associated with your Autodesk Account recently?
Tasha Addington-Ferris
Autodesk Fusion
Technical Support
abdurrahmans338
Nope all I did was clear cache as I had 3 project files stuck uploading for 2 days @tasha.addington-ferris
Autodesk Support
Autodesk Support
Okay. It sounds like you might need a case with our technical support team to get this figured out. I will create the case and email you for next steps. Sound good?
Autodesk Fusion
Technical Support
abdurrahmans338
Sure thing
