Looking for a Post Processor for a CR Onsrud Router with a Fanuc 0i-MF
chrisr
Message 1 of 10
chrisr
I am trying to find a way to get a post processor for a CR Onsrud 122S18 Router with a Fanuc 0i-MF controller. We have been using Vetric V-Carve pro and have a post processor that works. So far I have not been able to get the generic Fanuc post processor to work. It would be great our company to switch over to Fusion, I use it personally on a milling machine, but I need to sort out the post processor. Any help or advise would be greatly appreciated.
Replies (9)
Message 2 of 10
nick.narzinski
Message 3 of 10
hollshwanderc
Hello Chris,
As Nick mentioned, using the Onsrud Fanuc 31i post processor will give you the results you are looking for to post code for your machine.  This is a 5 axis post processor, but will also generate 3 axis code, too.  I worked with some guys in one of our other shops about a year or so ago after they purchased an M Series machine from Onsrud.  Their machine is 3 axis.  Is yours 3 or 5 axis?  If it is a 3 axis machine then you will need to set the parameters in the post to be as follows: Has 5 axis = No(Setting in Properties)/False(Set in Post) and Force IJK Yes/True.  But if it is 5 axis then the code should run without issues.
Hope this helps.
Chris H.
Message 4 of 10
chrisr
Thank you I will give it a try.
Message 5 of 10
chrisr
Thank you for the information! Will update after.
Message 6 of 10
chrisr
Thanks again for the help! Up and running after a few minor adjustments.
Message 7 of 10
hollshwanderc
Glad things worked out for you.
Chris H.
Message 8 of 10
matthewaarondesign
Hey I know this is 2 years later, but what adjustments did you have to make for this post processor to work? I am tasked with finding or writing a post processor for Fusion so my company can utilizes their 3-Axis CR Onsrud M-Series with a Fanuc 0i-Pendant controller.
Message 9 of 10
hollshwanderc
If you make the suggested changes when posting your operation files, as what I mentioned in the response from 2 years ago you should be able to use that post processor without issue.  But if you prefer, you can send me a private message with your email contact info and I can get in touch with my colleagues that are running the post with their M Series machine. I can get a copy of it from them and also put you in touch with them, in case you have issues.  We have a G Series machine with an Osai control in our office.  When we were doing the testing I worked directly with CR Onsrud and the Fusion team to make the necessary tweaks needed to make their machine run properly with the output G-Code.
Chris
Message 10 of 10
matthewaarondesign
Dm'd.
Thanks so much!
-Matthew
