Login and weird behavior.
Piotrek_Szarek
Piotrek_Szarek
Hello everyone ,
Here are my problems :
First is , F360 asking for login every time i open application .
Second, sometimes when i maximize window after doing something else there is only a black screen and there is only a design tree on the left, only way to solve it is create a new design in window options in left upper corner . ( Really hard to record , I tried )
Im using 2019 MacBook Pro 16 .
I was trying all ideas from other posts , with files in system library etc , reinstall including .
Thanks !
jhackney1972
One of the reason you have to log in every time is because you do not have permission to write to the Loginstate.xml file.  Take a look at this web article and see if it helps.  The other situation you describe sounds like a graphic card issue but since I do not use MAC products, I will stay away from recommendations in this area.
John Hackney, Retired
Piotrek_Szarek
Thanks ,
I changed a loginState file . Changed from only me can write/read to all users . It helped only once . In next launch I had to login again .
LoginState can be changed by anyone atm .
